does the i7 come with thermal paste
3181 Views 15 Replies 9 Participants Last post by  conductor609
Lozl random question.
Does the i7 920 come with thermal paste? Just wanna make sure because I am impatient and don't want to have to wait to put the system together for something like that
1 - 16 of 16 Posts
It will come with a stock fan that will have thermal paste on it. Don't expect great temperatures, though.
Yeah it will. IT comes with the stock cooler.
edit:
I never get first reply.
What about liquid cooling? Does the waterblock have it pre-applied?
No it wont you will have to apply it to the cpu. then you would put the waterbock on the cpu
any thermal paste reccomendations?
Originally Posted by Juggalo23451 View Post
I suggested IC Diamond thermal compound above
This one is the best, but Shin etsu, Artic Silver 5, and MX-2 are also great. Not as top as the one suggested but still good.
OCZ Freeze or Shin Etsu are good Thermal Paste's, AS5 is not that great anymore, it is a good cheap one, but not the best.
Confirmed to be better than AS5. And of course there's always IC Diamond
edit: duh forgot OCZ Freeze. Also not bad
I said that.
But still better than the thermal paste. I am switching (will switch) to Shin-etsu wants I have access to my kazuho-chan.
The way you apply the TIM also affects the temperature too. Not sure if it also applies to the i7 processors though.
the cpu comes with a stock heatsink fan that has thermal strip paste pre-applied on the heatsink.
EDIT: I use TX-2, got better temps then AS5, MX-2 & zalman TIM
I have mx-2 , but to be honest you probably won't see much of a difference by just switching thermal pastes (unless the one you had prior was absolutely horrid)
1 - 16 of 16 Posts
