1 - 10 of 10 Posts
I have an almoast year old nforce 4 motherboard 133-P4-NF51-AX i really want core2duo and i have the money but i dont have any extra to buy a new mobo if i cant get the c2d to run on my motherboard then i'll just have to deal with a Pentium D 930 which isnt terrible but i really want more power
Filthy Casual
Core 2 won't work unless it's been made in the last 6 months or so. Look it up on newegg and see if it says the Core 2 chips are supported.
well idk i might have gotten it somewhere around 7monts ago but newegg no longer sells it i really want c2d is there any kind of bios update i can do? cause i know it can handle the D930 which is socket 775
No nForce4 boards supports C2D, and won't be able to very soon.
I remember when......
It's not about the socket, it's about the BIOS and the board design. there are many boards that did not support C2D, but then were re-designed and then the new versions of the boards would.
I don't know of any board available for retail sale 7 months ago that will run a C2D. I believe July was when the C2D motherboards began to become available.
There are some nForce 4 boards out now that support C2D.....but as they are nForce boards, they are terrible overclockers.....
Not the nForce4 for C2D, is there?
1 - 10 of 10 Posts
