1 - 9 of 9 Posts
I guess it right around what I expected.. But I was hoping for just a tad lower..
My setup consists of
Q6600 Lapped @ 3.40 - 1.47v bios/1.44 windows load
Apogee GTX (copper top)
Black Ice II W/4 120mm fans push>pull (generic fans)
Db-1 Pump
Swiftech Micro Res rev2
All tubing is 1/2"ID - 3/4" OD
My current load temps seem to peak at 56-58 hottest core.
With my Lapped TRUE push>pull config I was getting between 62-65 hottest core. thats about a 7c drop overall in load temps which is nice.
So does that sound right?
And where would be my biggest improvement to focus on next?
I was thinkin of grabbing some yate loon High's
or
Better pump?
Bigger Rad?
My only dislike so far is my 285GTX exaust is right into the rad, so Im grabbing some L brackets to install it different.
Discussion Starter · #6 ·
thanks guys...
I am def getting the yate loons... Will put priority on the pump as well... the $100+ rad will have to wait a month or so tho... getting a bit tight on $....
Got decent load temps tho, and better than before so....
You could improve on the pump and fans if anything.
If ya used AS-5 it will set in 3 -5 days and lower the temps at least 2 -4º.
Shoot us some pics....if ya can.
Discussion Starter · #8 ·
Im using OCZ Freeze, from past experience it is exactly as effective as AS5 and has no cure time :) But thanks for the advice......
I am working on pics... will get them up by the weekend....
1 - 9 of 9 Posts
