1 - 8 of 8 Posts
trying to tighten up the timings on this ram a bit, im running 4,3ghz 24/7 but think i could get more out of the ram. right now im running them at box setting 9-10-9-27-1t 1.65v been trying to lower in -2,-3,-2 but have not had any luck, anyone here use this ram? if so do you have it underclocked?
runing at 1650mhz in bios
Totally New to OCN
you shoudl atleast be bale to get them down to CL 8 at 1600mhz , thats pretty common for 4GB sticks in tri channel
Dirty Jerzy in the house!
If your mems are ver5.11 or ver5.12 (Hynix-based, like the most of 2000C9 Dominator GT I've ever seen) then you shouldn't have problems running them at 825MHz with 8-9-8-24 sort of timings.
Whether you can go CL7 (to 7-9-8-24) or tRP 7 (8-9-7-24) - depends primary on luck.
1 - 8 of 8 Posts
