So I'm not really sure what's going on here.
Long story short I've been having memory issues for a very long time. Many many RMAs have happened and I got ADATA to exchange 4x 2GB sticks to 2x 4GB sticks (plus some swag lol). So far everything has been a little weird.
The sticks are AX3U1600GC4G9-2G. They are 1600 and as we know when you first put the sticks in there the system defaults to 1333. I put it 1600 from the bios and used it for a few days.
I started noticing a few weird things with my system. I wasn't sure if it was just a crappy program or something bad. I started running Prime95. When I came back to check on progress it was gone. My computer restarted. I found it weird cause I have it to not auto reset on stuff like BSOD.
So I started again and watched very close. After around 10 mins my computer just restarted. No errors nothing. So I went from 1600 to 1333 and ran Prime again for 24 hours. Everything went fine there was no errors. So I then decided to run MemTest 86+ just to rule out stuff. Ran it for 24 hours no issues.
After those two tests I figured everything would be fine. Then last week and yesterday was when some other stuff happened. At the end of the day I shut down my computer, I don't flip the switch on the back but I just leave it off. After around 2 days of no use I turned on my computer and before I even got into Windows I BSODed. There was no error with it like about the pagefile or anything. It did give me a stop code:
Here is the one from today. So far it only comes up if I've had my computer off for a few days. After restarting the computer everything is fine. No BSODs or anything.
Today though my computer did freeze. So I ran SuperPi (I believe that was the name) on the highest MB setting and it's fine. Running IntelBurnTest now.
I guess i don't know what's going on. From the tests I've done everything should be fine.
Are there other tests I can run to see how it's going, or should I be looking at something else? Could it be something connected to my computer causing it?
The following is connected to my computer:
I have my bluetooth keyboard/mouse dongle plugged in one of the USB ports, a external HDD by the mobos esata ports, a internal memory card reader by USB, 2 monitors, speakers, and a USB webcam.
Any ideas? Am I over reacting?
I feel like I should also be able to get these to 1600 fairly easy. My other sticks where able to do it with no effort.
