don't understand!
392 Views 9 Replies 4 Participants Last post by  kenny1064
I am having a problem with my memory. my fsb was set at 270x9 htx4 which put my mem at ddr540. It ran memtest for 6 hrs with no problems. Then i ran memtest again about a month later and it showed errors at the end of test 5. I was going to attempt to get lower timings, but this just ruined that idea. can anyone help?
1 - 10 of 10 Posts
try dropping your HT to 3
Good advice.
does this mean that i've hit my peak. if thats so then i am disappointed with this memory.
It's not really that. Your HT bus is way over 1000. Dropping your HT to 3 will get it under 1000 again and hopefully get you some stability.
appreciate that, guys!
No problem...see us intel guys aren't all bad.
Yeah, but those AMD guys, I just don't know.
Don't feel too bad at least your ram can get 270, I can't break 260 with mine... I had really hoped for a little bit more than 260...
with my 1gb dual channel ocz el platinum i got 295. maybe i should have stuck with 2gb of ocz.
1 - 10 of 10 Posts
