1 - 6 of 6 Posts
Starting to become a BOFH
I d/l'd this so that I could play Commander Keen with some real sound instead of the PC speaker. But its giving me more problems than solving. I need to brush up on my DOS skills, but thats what the internet is for. Anyways, I try to acces the folder COMMAN~1 (The folder with my commander keen games) and it says that I can access it. What gives? Plus, I also d/l'd it from <a href="http://www.dosgames.com" target="_blank">http://www.dosgames.com</a>, with the other utils on it.
<tr>
<div>
Originally Posted by <strong>legoman786</strong>
</div>
<div style="font-style:italic">I d/l'd this so that I could play Commander Keen with some real sound instead of the PC speaker. But its giving me more problems than solving. I need to brush up on my DOS skills, but thats what the internet is for. Anyways, I try to acces the folder COMMAN~1 (The folder with my commander keen games) and it says that I can access it. What gives? Plus, I also d/l'd it from <a href="http://www.dosgames.com" target="_blank">http://www.dosgames.com</a>, with the other utils on it.</div>
</td>
</tr>
</table>
</div>Take a look at my FAQ for Ultima Underworld. Use normal short DOS names at the root directory. Also change the polling speed.<br />
<br />
<a href="http://www.overclock.net/faqs.php?u=23871" target="_blank">http://www.overclock.net/faqs.php?u=23871</a><br />
<br />
EDIT: And take note of the mounting procedure. You need to mount a folder to see it in DOSBOX.
I mounted c:, shouldnt that work for all folders in my drive?
<tr>
<div>
</div>
<div style="font-style:italic">I mounted c:, shouldnt that work for all folders in my drive?</div>
</td>
</tr>
</table>
</div><br />
Maybe, maybe not. Dosbox is so old, it may be barfing on the naming conventions. Just create a simple sub-dir and mount that.
Reactions: legoman786
Discussion Starter #5
I'l probably remane the folder and try again. Plus, I found that DB was reading my SB card from IRQ 7 when its on IRQ 18
Discussion Starter #6
Haha!! Thanks for your help FrakenPC!! Now I need to make an uber short shortcut to get my games running immediately!
1 - 6 of 6 Posts
