1 - 7 of 7 Posts
First of all ... make sure am not Lazy google hater
but simply i tried everything possible posted here and in other forums with no luck + am tyro in BIOS options and concerned to make a mess
the 10xBillion posted problem is DRAM Frequency in CPU-Z it read 530.6 rather than 800
i have: CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX6GX3M3A1600C9
mobo: XFX X58i
Bios configs is as follow:
BCLCK (CPU Freq): 133
QPI Freq: 800
Memorey Freq: 12 x
UnCore Freq: 24 x
DIMM Voltage: 1.650v (ITS MARKED AS RISK RANGE! normal?)
DRAM Timing Mode [Auto]
INTEL X.M.P Profile: [Profile #1]
tCL: 9
tRCD: 9
tRP: 9
tRAS: 24
please avoid advising me to make Memory Frequency to 1600
(i mean how)
(SCREENSHOTS)
http://img842.imageshack.us/i/170120111962.jpg/ (BIOS)
http://img171.imageshack.us/i/170120111963.jpg/ (BIOS)
http://img6.imageshack.us/i/170120111964.jpg/ (BIOS)
http://img823.imageshack.us/i/memorya.jpg/ (CPU-Z Memory)
http://img6.imageshack.us/i/spdl.jpg/ (CPU-Z SPD)
Thank you.
Iconoclast
Firstly, XMP is a disaster waiting to happen. Most XMP profiles will jack up uncore voltage (aka QPI/VTT) to the 1.5 to 1.6 range, which is beyond what most people would consider safe for 24/7 operation, at least without exceptional cooling.
Anyway, most of your BIOS settings do look correct for running DDR-1600. Try setting everything to manual under the DRAM performance settings.
just tried to edit the entire DRAM settings Manual with no luck
wondering what it would be ?!
what am doing wrong
notice that my Current DRAM Frequency :1064 (133x08)
while Memory Frequency is manually set to [12 x]
Discussion Starter · #6 ·
Originally Posted by redhat_ownage
set auto ram timing, turn off xmp, set cpu vtt to 1.25V.
thanks for help all , but the fact is the x58i maximum memory is 1333
otherwise will have to OC both the cpu and the DRam as well
Iconoclast
You do technically have to OC the uncore to use DDR3-1600, but the BIOS settings you have listed should already be doing so.
1 - 7 of 7 Posts
