Driver for GeForce6800 Ultra NV48
1248 10
I really have prolem in finding the lastest Driver for GeForce6800 Ultra NV48 code because the 81.98 driver does not support my card !!
If anyone who are using this card and got the lastest Driver please tell me where to get it (I lost my CD Driver)
Thanks so much
1 - 11 of 11 Posts
I know that..but when I click install the Driver say that :
" ..cant locate any drivers that are compatible with your Hardware .."
by the way my VGA Bios is...
Graphics core : NV48 revision A1 (16x1,6vp)
$0100000001 Hardwired ID : 0210 (ROM strapped to 0210)
$0100000002 Memory bus : 256-bit
$0100000003 Memory type : DDR3 (RAM configuration 07)
$0100000004 Memory amount : 262144KB
$0100000005 Core clock : 398.250MHz
$0100000006 Memory clock : 552.000MHz (1104.000MHz effective)
$0100000007 Reference clock : 27.000MHz
$010000000b HW masked units : pixel 1111b, vertex 111111b
from Riva tuner...
I've just installed the 79.11 Beta Driver on 3D guru..wow it works..but in device manager..my VGA displays as the name " NVIDIA NV48" wow ??? with the older DRiver 71.89 (not WHQL) my VGA displayed as "NVIDIA geforce 6800 Ultra"
I'm wondering...what's going on ??
please help
The latest forceware driver should work with your card. It would be stupid for Nividia to make a driver that supports every other card other than yours. LIke others said be sure to use driver cleaner and remove any remnants of the old drivers. I used the 81.98 on my 6800GT and my 7800GT, and it worked fine on both cards.
Discussion Starter · #11 ·
I tried 81.98 MANY time and..no chance to use this Driver...I have to use 79.11 Beta now..but it works..
lonnie5000..you can use this Driver..cause your GPU is NV40, and 81.98 support it..but my GPU is NV48..(a different one)
I really mad in findding my VGA "hometown" cause I even dun know which company manufactured my VGA ,..the only thing I know is.. it use NVIDIA NV48 GPU
1 - 11 of 11 Posts
