1 - 7 of 7 Posts
Chainsaw noise far off
Intel is set to launch two new cpu's with unlocked multipliers!
"Intel plans to launch two processors - Core i7-875K and Core i5-655K - that have unlocked multipliers and are targeting the gaming market, according to sources from motherboard makers"
http://www.digitimes.com/news/a20100324PD218.html
The proper way to do a news post is with the source in the title in brackets, and with a quote of an excerpt from the article (unless it's a video). You can add the source by hitting edit and going advanced, or by double-clicking the edit button. You could add [Digitimes], or shorten it to [DT].
As for reposts, yeah, it can be tough to find the original. Anyone calling a repost should link to the original article, because it needs to be tracked down to confirm the repost.
Thanks for the simplified explanation.
No problem. If you put the excerpts in
tags, they'll
look like this,
which helps them stand out from any commentary you add, and lets you include things people have said in your excerpt without getting confusing with all the quotation marks.
1 - 7 of 7 Posts
