1 - 8 of 8 Posts
Can I use this PSU to power this card?
The dual 12v+ rails has me questioning everything. Would this be pushing it? Thanks in advance.
Edit: I ask this because the card claims to need 38a on the 12v+ rail, and I have two with 22a each. I understand that the amps don't combine and whatnot, but I can't figure out exactly how much power the card will actually require.
· Premium Member
Rails
Do not
Matter.
What does matter is that your PSU is a piece of garbage that realistically do about 350-400W. Raidmax have a little habit of "exaggerating". Just a little.
Reactions: 5outh
Yeah definitely do not go with Raidmax psu's especially if you are planning on gaming. You are going to have to spend a bit more money for a better psu. Check out Corsair or Seasonic.
· Not new to Overclock.net
Reactions: 5outh
Originally Posted by 5outh;13116507
Wow, cheaper too. Thank you!
You're welcome!
Plus, this PSU (and other quality 650W power supplies) will be able to power your system with two 5850s in it.
1 - 8 of 8 Posts
