1 - 4 of 4 Posts
So, I've backed myself into a corner case-wise on my first build. Rookie mistake, I know, but I'm a rookie
(If you must know why, check my old thread here :
"http://www.overclock.net/intel-gener...ld-doable.html)
To make a long story short, I'm weighing my cooling options on a new i7 2600k (slightly overclocked, nothing insane) build that can't fit a top performing air cooler. I know there are a bunch of different ones out there but, in your opinion, is there any dual (or triple, though I haven't seen one) 92mm fan radiator that would be worth using instead of top down air, or should I just save the custom water for the next project I am sure to do?
1 - 4 of 4 Posts
