1 - 6 of 6 Posts
Is there a dual boot software that would let me choose from different drives? . . like my windows is on one drive, Xandros on another, and gentoo on a third? . . . this would help me from switching it everytime in bios. <br />
<br />
Thanks for the replies
the GRUB bootloader. If you install Xandros or Gentoo last then the option to install grub should be available, at least I know it is with Gentoo.
Reactions: DanNEBTD
Or you could change the order of the hard drive boot, everytime.
404 Title Not Found
GRUB is pretty good as mentioned above, I have used that before. Might be a little confusing to install but its pretty easy to get the hang of.
Reactions: DanNEBTD
As long as the MBR of the other OS's are on the main drive then the GRUB should work for you just fine.
or u could just partition that will work i guess
1 - 6 of 6 Posts
