I'm trying to install Ubuntu studio on a second partition to dual boot with Win 7.
I created two partitions in Win7. Booted from the Ubuntu CD and am at the partitioning part of the setup.
It says;
"This is an overview of your currently configured partitions and mount points. Seect a partition to modify it's settings (file system, mount points etc.), a free space to create partitions, or a device to initialise its partition table."
Below that, there is a list of drives;
SCSI1 (0,0,0) (sda)
#1 primary 166.9 GB ntfs
#2 primary 83.1 GB ntfs
and more...
I want to use the #2 partition here. The 83.1 GB one.
If i hit enter with '#2' selected, I get different options.
It says,
"Use as: ntfs
Mount point: none
Botable flag: off"
Are these settings correct?
Then there are options
"Resize partition
copy data from another partition
erase data on this partition
delete the partition
done setting up the partition"
If I select "done setting up the partition" it takes me back to the list of drives.
The partition is freshly formatted (zero data).
What should I do?
Thanks a lot
It says;
SCSI1 (0,0,0) (sda)
and more...
It says,
"Use as: ntfs
Mount point: none
Botable flag: off"
"Resize partition
What should I do?
Thanks a lot
