1 - 4 of 4 Posts
Hello,
I was wondering which would be best.
Since the 7950 are like low $200 now, Should i buy one more and run dual cards?
Of should I just upgrade the card with something new?
Has AMD fix the crossfire driver issue yet? (For people who have dual AMD setup, did you notice a difference in frames?)
I game @ 2560 x 1440
Card I have now :http://www.newegg.com/Product/Product.aspx?Item=N82E16814202007
Thanks!
Old / New to OC.net
if you can wait for 9000 series, wait. if you cant buy another one..
AMD didnt fixed yet. depending on your definition of fixed... micro stuttering is games specific.. but AMD seems to be in the right track for fixing microstutter... just buy one.. you can always sell later...
and also, if your current gpu cannot handle games with ultra settings, or high settings on you 1440p monitor, then crossfire. if your still happy, stay single card...
yeah I can wait. Some games I can run maxed out, some not. I was just looking at it this way... $200+ for dual or $300-$500 for a single card (9000 series, I'm just guessing a price) and would it be a worth it.
Old / New to OC.net
nobody knows performance of 9000 series yet. but price would be like what you mentioned....
question is though, is it worth going from HD7950 to 9950? nobody knows yet..
1 - 4 of 4 Posts
