1 - 5 of 5 Posts
I don't know what's up with this junk....but whenever I try to run two large fft tests it just doesn't work right. One time core 0 will fail...the next, core 1 will fail. What's wrong?
I installed x2 driver and the MS hotfix too...so I don't know what's wrong with this junk.
Any ideas? Anybody else having the same problem?
Umm...I'm kinda having the same problem. My problem is that no matter what speed I'm at or how I setup dual prime one core will never do the test. So, I always have 50% in task manager, and it seems like randomly one core will not run prime at all while the other one is. I'm not sure because I haven't checked but I think that the core that I start prime with second, or vice versa, will never do the test.
Originally Posted by foneone
are you stock or oc'd?
either way i would say bump the voltage a lil bit
mine runs flawless 12-24hrs
He's OC'd and already found his "sweet spot" for voltage if I'm correct. I've been following his OC post
http://www.overclock.net/amd-cpus/69...-165-time.html There's his thread; take a look.
Sorry to answer for ya Sideburns, just trying to help speed things up for you though lol.
1 - 5 of 5 Posts
