1 - 1 of 1 Posts
will Bonic use both cards? I am only seeing the 1080 get the WU. is there a special config I need to do or its not possible?
Solved.
add the a cc_config.xml within F:\Apps\BOINC\Data with the correct syntax and it works woot.. time to heat up the room
1 - 1 of 1 Posts
