I have 2 problems:
Firstly, when I boot up, the PC always boots to my Internal VGA rather than my GPU. I've followed several guides, reset all the booting priorities, but I have never been able to solve this, its not software related as I've used multiple operating systems and never solved it.
To boot onto my GPU I have to go onto BIOS Settings, then Exit + Save Changes (I've learnt what buttons to hit on the KB after several years so that I don't have to muck around with my VGA cables.
Secondly, following my upgrade to Windows 7 Ultimate I was unable to use my Multi Monitor setup, until the recent nVidia update. Setup wise, I have a 19" Hitachi TV/Monitor Combo (its disgusting, really) and a 15" brandless monitor my OS refers to as "L5AK5" (also ****e
). Basically, if I want to get the dual set up working, I have to boot up using my 19", then plug the 15" in, change the settings to Extend display and then change the 19" back to primary.
If i boot up with them both plugged in, the 19" gets no output and is blank, where as the 15" displays what it should.
I'm overdue a new set on monitors and I should be replacing the 15" soonish but I'm skint to say the least.
Thanks for any help.
