1 - 4 of 4 Posts
Dear OCN,
At work I have a HP branded microtower with a not so powerful powersupply ( 300 or 350 watts). Now the microtower itself does not support a dual monitor setup. Im looking for a low profile no nonsense just for setting up dual monitors graphics card without having to replace the psu. Since it wont be used for any gaming or high def streaming whatsoever it should be as cheap skate as possible.
Does anyone have some good suggestions? Im dying to find out because i failing atm to find a decent card for this lol
thanks in advance
m1nd
The easiest thing to do, if you are only using this for browsing and office work, would be to pick up a USB to VGA video adapter. Minimal cost and it won't effect your PSU.
USB to VGA Adapater
What resolutions are you wanting to use the monitors at? What socket, pci, pci-e, agp?
1 - 4 of 4 Posts
