1 - 4 of 4 Posts
Do you really need it?
Are you hooked up to a 1Gb switch and have other 1Gb machines that you will reading while writing on the same LAN?
If you plan to team... the better setup would be 1+1Gb but again... do you need it?
Tappy tap tap
Originally Posted by Tator Tot
You need to check if you have a teaming driver for your NIC's.
I'll look into that.
The entire network is Gigabit here at my school, so it would work. I might not really need it, but it would be cool to tinker with.
1 - 4 of 4 Posts
