1 - 18 of 18 Posts
Originally Posted by profit8652;11916548
now i am confused the qx9770 isn't a 775? and if it is which i believe it is, how will it run on the board and not the 9550
ahh i was excited to see the board i stand corrected. damn..
so i am basically sol
the 9770 is 775. but you can only use the 9775 on skulltrail. the specs of the two processors are identical
qx9770 is LGA775 http://ark.intel.com/Product.aspx?id=34444
There just aren't any dual-cpu motherboards for LGA775--you'd need Xeons (LGA771)
Blue and Green Team!
LG771 has the P2P tech required for inter-CPU communication. LGA775 doesn't.
There is no restriction to which OS you can use on a dual socket board.
With the introduction of 6 core CPU's that have HT as well, I think building a dual socket LGA771 machine is a waste of time and money. Because it may be a little older but will still cost a bomb.
1 - 18 of 18 Posts
