My motherboard is a BOX865PERLL it supposivly Supports Dual Channel DDR 400/333/266 SDRAM Memory module. I am under the impression that this means if I have two sticks of equal memory that it would actually run faster than having one stick that is the same speed and size. But, I have four slots. Two grouped together on the left and two grouped together further to the right. In the book that came with my Motherboard it says the set up goes like this. The far left one is DIMM0 and the other slot on the left is DIMM1 then the two grouped on the right are the same. So, in order to use this duel channel capablility, and I have two pieces of memory, would I place them both in either DIMM0 or both in DIMM1. In other words, do I place on in the far left and one in the left side of the two slots grouped on the right? Or does it even matter? Also, does it really matter if I use the DIMM0 or DIMM1.
Thanks for any help you can give.
