1 - 3 of 3 Posts
My AGP Apature size should be 256 now right? it was still 128 for the 9800pro, i assume it needs to be 256 but just wanted to make sure. need to check my brothers bios too he upgraded to a x700pro, thanks guys i know tis dumb
you should probly set it to half of your video mem. this number is assigning the amount of system ram that will be used for the video processing. If you do not have a lot of system memory then you would want to keep this number pretty low. On the other hand you will not see much of a gain with a higher number, if you are using this system for gaming and general use. So if it is set to 128 than it should work just fine
1 - 3 of 3 Posts
