1 - 6 of 6 Posts
What one is the best option between those, considering also bang for the buck:
- AGM X2.
- AGM X2 SE.
- Wait for the AGM X3.
- Blackview BV8000 Pro
- Blackview BV9000 Pro
- Wait for the Black view BV9500 Pro.
404 Title Not Found
Got my first ip-68 rated phone a while ago, never going back.
Kyocera Duraforce Pro. Might be cheaper/older than some of the ones you listed, but it's holding up super well.
Doogee S80: 5.99" | 6GB+64GB Storage | 12+5MP Dual Rear | 10080mAh | IP68丨MIL-STD-810G | Android 8.1 | weight 398g |
Poptel S60: 5.7" | 6GB+64GB Storage | 16+5MP Dual Rear | 5000mAh | IP68丨MIL-STD-810G | Android 8.1 | weight 248g |
Nomu S50 Pro: 5.72" | 4GB+64GB Storage | 16MP Rear | 5000mAh | IP69K丨MIL-STD-810G | Android 8.1 | weight 250g |
For sports you should not carry your cell phone because I tried brands like Doogee and found many problems in the software so get a reliable cell phone from good brands (if you want my suggestions tell me your budget and usage) and for sports get a smart band or smart watch . Look here:
https://www.samsung.com/us/mobile/wearables/
1 - 6 of 6 Posts
