Originally Posted by Cypz I just want to know what kind of product you guyz use to clean your rig? I use air gas duster is it safe? |
Originally Posted by ATVkid*AFZ* yep, it'll cause frostbite, apparently from what i read on the can...heh. yep, best bet's to turn it off and then start spraying, i use air from my compressor w/ a regulator on it. works great, and doesen't cost anything for compressed air too! |
Originally Posted by spookedjunglist when im about to clean my rig i drop my MOBO tray and leave both sides of the case upen and i set a fan blowing through the case, and i use a can of air to blow the crevices and the mobo and the big fan blows the dust all out the case... and i vacume after that of course ![]() |
Originally Posted by DeaDLocK I would not use compressed air since your blowing the dust deeper into cracks and into slots... If your trying to get the dust out I say use a vacum cleaner with a small nozzel attachment and get a cloth thats thin and stretch it over the hole and secure with either tape or just hold tight with your hand... Run nozzel about 4cm away from surface your cleaning to suck up all the dust. |
