[DvH] GELID Tranquillo CPU cooler revealed
2573 Views 36 Replies 25 Participants Last post by  Pheatton
5
GELID has introduced the Tranquillo, a new CPU cooler for the latest AMD and Intel processors. This model has four heatpipes, an aluminum tower heatsink and a 120mm PWM fan with a noise level between 12 and 25.5dBA. It will be available in retail stors for $38 (28EUR).
Source
1 - 20 of 37 Posts
I like it. Gelid makes some nice stuff for the price. I love their fans.
Hm... I wonder how well this thing performs.
Four heatpipes and averaged sized fin superstructure; probably somewhere around Xig Dark Knight.
Are you kidding? This isn't HDT. It's got a base. So theoretically it should be around half as good as a TRUE?
No, I am betting it WILL compete with the dark knight. HDT isn't really all that special IMO.
looks pretty midrange on performace imo
I think it'll make a decent budget cooler but won't come close to competing with the top.
This cooler reminds me of a OCZ Vendetta 2, minus the HDT and given a weird shaping on one side. I doubt that you could do push-pull due to the design, I'd be surprised if this could keep up with a Mugen 2.
Top 5 or so coolers are not HDT at all.
Noctua D-14? nope.
IFX-14? nope.
Megahalem? nope.
TRUE? nope.
Cogage TRUE? nope.
Mugen 2? nope.
Do all of those beat anything HDT? yup.
On topic, this cooler looks like crap but performance reviews will determine if it is even a worthy choice.
Noctua D-14? nope.
IFX-14? nope.
Megahalem? nope.
TRUE? nope.
Cogage TRUE? nope.
Mugen 2? nope.
Do all of those coolers have more than four heatpipes?
Yes.
Yes.
The Cogage True spirit and IFX-14 have 4 heatpipes.
(though the IFX's heatpipes are 8mm)
Yes.
Most of them are also huge in comparison.
I'd really like for a company to make a heatsink with two versions. One with the normal flat base like on the TRUE. The other with HDT pipes. Nothing else about the cooler would be different.
That is what I need to accurately compare the two CPU cooler base types. Otherwise, there are too many variables.
Of course, I don't see the point from a business perspective, but I can dream, right?
The problem is that you can only really fit 3 heatpipes over a cpu, and those 3 are so good at carrying heat away that embedding more above them isn't going to do much.
HDT is clearly the superior design, since it gets 90% of the performance from 50% of the mass(and price!), but its just limited in design.
They need to figure out how to branch heatpipes, then we could have a 6 heatpipe version that narrows to 3 heatpipes and makes the TRUE and Megahalems look like the Intel stock cooler
If HDT is clearly the superior design, why are all of the top performing coolers non-HDT? HDT coolers might be a little less expensive but saying it's superior is a little misguided.
Wait how are you supposed to put another fan on this thing, the other side of the fins are pointed!
It seems they are superior in size vs performance. Thats about it really. And cheaper of course.
Because the top coolers have 6 heatpipes (Or 4 8mm heatpipes), way different designs, etc than the top HDT ones do, I'm sure if the TRUE was HDT it'd be much better.
A Mugen 2 competes with a TRUE and a Megahalems, there is no way this cooler will be remotely close to a Mugen 2.
Anyways it looks like it will be good value.
1 - 20 of 37 Posts
