1 - 3 of 3 Posts
hi got a new hanns g 19 ws and i have a 6800gt nvidia card , also vista rc2 with new nvidia rc2 drivers <br />
when i use the vga cable screen is fine and goes to 1440 x 900 clear as day <br />
but when i plug in the dvi cable screen is brurry esp text , and res wont go past 1280 x 1024 ? what can i do
Are you using a dual link DVI cable or a single link? The dual link will have all the pins (24 i think) and a single link will be missing some in the middle. If your using single link try a dual and it should fix the problem.
Reactions: rippling
cheers looks like it is a single link cable thanks for the info!<br>
rep for you!
1 - 3 of 3 Posts
