1 - 7 of 7 Posts
Hi all. Need a Little help finding something.
As you can see the first photo attached is the plug on the back of my monitor.
I am trying to hook my monitor up digitally through my DVI port on my monitor.
The only thing is all the DVI adapters look like this..
I cant seemed to find the right adapter on line.
Yes i have tried the manufacturer.
Could someone help me find the adapter for this monitor??
Monitor:
Princeton
VL1916
Are you talking about the DVI port on my monitor itself? I have to DVI adapters, but they both look like to one you have in the picture.
Thats my problem. I have 2 adapters myself. But they both have pins around the spayed pin and my monitor does not.
Would you think it would be safe to cut those pins off the adapter??
Discussion Starter #5
Originally Posted by shortfuse
there are two class of DVI connection 1 is analog and one is digital 6800. The first link u showed is analog and the second one is digital. check this website they mite have it. make sure ur specific it has to be DIGITAL not analog http://vastercable.com/
So let me clarify that the LINK i provided is analog and the attached photo is digital?
If so can help me find the correct adapter?
Opps Edit thanks for the link!
Discussion Starter #7
Yes link is analog and attached photo is digital. try this website www.vastercable.com if u dont see it on the catalog parts. u can email the sales department.
Thank you Thank you.
1 - 7 of 7 Posts
