1 - 3 of 3 Posts
is there a simple device that can be used to hook a dvi lcd monitor up to a regular vga card. cause i was looking on newegg for a dvi female to vga male adapter and they had them, but all the reviews on them said that they didnt work and thats not what theyre made for
well what i was giong to do was hook my lcd up to a kvm and i didnt want to buy an expensive dvi kvm so i was just going to use an adapter. im using a dlink 4 port kvm and id probably get this adapter just cause its the cheapest one. all of the reviews say that it doesnt work right or somethin, but i just want to be sure. do you think that all would work?
1 - 3 of 3 Posts
