1 - 5 of 5 Posts
sig ig monitor no longer accepts a feed from the DVI port.
Tried other DVI cables, none work. If I swap to a VGA cable with a DVI to VGA adapter for the video card end, I get a display.
any ideas on how to fix? I'd love to keep using my DVI cable / input rather than VGA. I can tell the difference xD
Originally Posted by xxicrimsonixx
Try to reinstall the driver. Should be located on the Acer website.
If the driver does not work, then try and e-mail Acer, they might have a easy software fix for it, or they may need you to send it in.
wait.....
monitors have drivers?
Originally Posted by xxicrimsonixx View Post
***** sorry, didn't fully read post..
Um, I think you will need to call monitor manufacturer for warrenty, cause the port is working...
yeah. I've already emailed them, so we shall ee. the monitor is over a year old, so IDK if they'll warrant any repairs.
1 - 5 of 5 Posts
