DVI To HDMI Vs VGA
2047 Views 30 Replies 16 Participants Last post by  HoldYrPistlstr8
I have a 2009 Samsung 40" 120Hz LCD (LN40B630) 1920x1080. What should I use, DVI To HDMI or VGA?
1 - 20 of 31 Posts
any reason?
Originally Posted by shizdan
any reason?
I'm thinking digital > analog, but I'll let people more knowledgeable about this help you further.
DVI, you can send sound through it too if you want. HDMI and DVI are almost identical, both digital, except HDMI also does sound. And I agree with JK, can't give you a technical answer.
Use DVI to HDMI. It's digital, unlike analog VGA, and will probably be more supported by your other gear in the future.
I don't believe that VGA can carry a 1920x1080 signal.
It can carry up to a 2048x1536 picture
Well I switched over to DVI to HDMI and it looks terrible!
Definitely the HDMI, that video card will pump out 7.1 sound over DVI-->HDMI.
How so...that doesn't make sense
Make sure the resolution is set to the native resolution of the TV. They aren't always the exact PC resolutions. Just put it as high as it will go and then try a couple others and compare.
http://www.amazon.com/Samsung-LN40B6.../dp/B001U3Y8Q8
Its set to 1920x1080
Also, go into your settings and play with picture settings. My 42" Sony had some settings to make regular channels look better by blurring and such. You'll need to make it display one pixel per pixel and that pixel only, if that make sense. Otherwise text can look horrible. Also, you'll need to remember that you have 1920x1080 pixels spread our over a 40" diagonal surface when your monitor would have them in 1/4 of the space. They will always looks worse from close up.
I've just done this, and after trying DVI> HDMI, I've gone with the simple VGA on my TV.
The main reason was that the TV seems to switch resolutions easier\\quicker over the VGA connection. I also had to do a lot of tweaking on the PC side to get the picture centered and the HDMI audio working.
If you have a decent VGA cable it will look the same as the digital connection anyways.
(edit) What fish was referring to about the pixles was called "full pixel mode" on my TV if that helps.
Use the HDMI input on your tv. In order to achieve the purest signal possible, cut down on the amount of signal conversions and/or manipulations. Your video card will output a digital signal to a digital input on your LCD. If it's fed the native resolution, your LCD circuitry will leave it alone and display it. If it's fed any other resolution, it will have to be converted and that will degrade the original signal.
If you use the vga input, your tv will be forced to convert it to it's native resolution before displaying it since LCD is a digital format. If you choose a different resolution other than the native, it will be forced to do a second signal conversion which will degrade the signal further.
Edit: I strongly disagree with the above statement that an analog signal will look as good as a digital signal on a digital television. If for some reason the digital input looks inferior, something is wrong with either the input circuitry or user settings.
VGA is fuzzy at 1080p and up, so go digital.
The text looks terrible!
Only if you have a really cheap VGA cable. Remember there were 2048x1536 CRT monitors that looked every bit as good if not better then any current LCD panels.
However, the cable that came free with a 15" CRT screen will probably ghost like crazy. I had to try 3 VGA cables I had lying around the house before I found one that worked good on my 1080p TV. It looks just as good as the HDMI connection did though.
Don't forget that he has an LCD and not a CRT. An LCD will convert any input into a digital format at its native resolution. If you ask it to display that resolution, it will then leave it alone. If you ask for anything other than native, it will convert the signal again. It's best to leave a signal as pure as possible.
1 - 20 of 31 Posts
