E2140 CAN'T overclock
869 Views 18 Replies 11 Participants Last post by  Nelson2011
Look in my sig- i have this crap Palit II-G31 mobo.
I have tried overclocking this E2140, and settings so far:
FSB= 240
RAM Freq = Auto (667/800)
DDR Ram Voltage = Auto ( 1.8V, 1.85V, 1.9v...)
This is all options which is allowed to be changed - no multiplyer, voltages, Vcore nothing. It takes me up to 1.92GHz only, and anyhigher wont POST.
I tried setting RAM freq = 800, 667 - only higher a BIT.
But when I set the FSB at anything higher than 250 other than 300, it wont post.
At 300, I can post! but get into windows finding that the FSB is still 278, and isn't stable on OCCT.
SHould i get a new mobo?
If so, i can't afford the p45 chipset - what other chipsets/mobos will take me up to at LEAST 2.5GHz-3.2GHz???
1 - 19 of 19 Posts
I'd say save up for the whole new build, it doesn't seem worth it overclocking that thing or upgrading the mobo for such outdated technology...
i don't have the money to even upgrade to p45- let alone i5.
I want to try extend the life fo this cpu for a few years more...
Try a lower multi and a higher FSB - sometimes they like to clock on a lower multi.
What strap (if your mobo tells you) are you running for your RAm/FSB?
What voltage options do you get?
Id say you dont have FSB and NB voltage and thats whats letting down your OC......my E2220 Oc's like a champ but my old G31 mobo would only get my E7200 to 3.4Ghz where my P5Q took it to 4.1Ghz
Try to get a cheap AMD build. An Athlon II build would be pretty cheap, and it would be miles faster.
Thats the point of overclocking - to make slower hardware go faster to get more use out of it.
Whats the point in getting the best comp and overclocking it? (other then benching)
Its funny how when you ask for help every buddy says go buy something new any way try messing with the ram I had a prob like this one time Had to turn my memory speed down a few to get the fsb up but I was using cheep ram
1) Can't change multi.
2) Cant change voltage - except DRAM Voltage
3) Whats a strap?
What he's saying is, overclocking won't get you very far on your current system. You could just upgrade your motherboard, but then the rest of your system will still be out of date.
It might be best to simply build a new rig. Someone suggested an Athlon II based system earlier and that would be the way to go if you're on a tight budget.
Honestly it looks as if your board is very limiting. Can you maybe afford a new board? Try going the used route here in the Classifieds.
any recommendable chipsets (other than p45)?
Ok with a decent cooler 3ghz shouldn't me an issue. Your mobo is horrible and is holding you back.
http://www.overclock.net/main-compon...0-shipped.html
Buy this
he can't get it to overclock... it doesnt seem worth it to buy a new motherboard, thats spending money for performance gain, overclocking is supposed to be at no cost, if he'll be spending money why not just get the new cpu and motherboard for a massive performance gain instead of just the slight performance gain in overclockability of the new motherboard
Like Mr. Stroker, I was going to mention getting a P35 board if you're really on a budget, and most of them from name manufacturers have all the bios settings you need.
However, it is debatable whether you should get a new motherboard to overclock the E2140. It would be a similar price to just replace that CPU with a cheap E5200 or E5300. Even though you would still have the same overclocking problems, it may end up being a better decision.
If you want to overclock because you enjoy it, then get a new motherboard and OC the E2140. If you are only OCing because you want more performance, but don't enjoy the process, then you would probably be better off with a cheap E5200 or E5300.
How about wanting more performance and enjoying the process? :)
Motherboard then
When you dont have a good mobo bios then its very hard to oc the cpu. +1 on a new mobo.
I can sell you an e6300 and a msi p45 neo3 for 100 shipped?
PM me I have three different boards that I can sell for cheap.
http://forums.ocworkbench.com/showth...t=81397&page=2
http://www.xtremesystems.org/forums/...d.php?t=238734
In this article, p45 is claimed to have this annoying shutdown/restart cycle after OVERCLOCKING, is this typical of P45 mobos such as Gigabyte, J&W, ASUS, etc???
Are oc's going to work?
Well mine just restarts when i dont get the right settings on my oc like not enough voltage.
1 - 19 of 19 Posts
