e2160 vs e8400
2293 Views 8 Replies 8 Participants Last post by  whe3ls
im new to all this overclocking so please dont be offended if u think im messing aound its just im lerning
if you have a e2160 1.8ghz clocked at 3.0ghz how would it compare to a stock e8400 at 3.ghz?
all i can see is the 5m more L2 but dose that make a huge difference???
1 - 9 of 9 Posts
It does make a big difference, plus the e8400 is based on the 45nm architecture that is 10-15% faster clock for clock in some cases. Of course, the e8400 will overclock easily to 4ghz in a lot of cases whereas the e2160 will top off 3-3.2ghz in most cases.
I've owned a e2160 that was @ 3.4ghz and my e8400 at 3ghz is much faster in all scenarios.
65 vs 45nm difference is not 15%.. it's the cache that would make more of a difference than the architecture. The clock per clock in same cache scenario can't be more than 10% and I think that's being really generous.
It mades a different but the E2160 is still the a good budget chip if you consider 67% OC on a $50 chip.
Let's make this simply. It won't win E8400.
The larger cache + 45nm would probably put the e8400 @ 15-20% better performance than the E2160 at the same clock speed.... definitely depends on the application though - I'm talking newer games + synthetic benchmarks
I owned a E2140 and E7200 and I would say my estimation is fairly accurate
it was big difference. i went from a e6600 @ 3.7 to a e8400 @ 4.1 i saw a 2k+ jump in 3dmark o6 with lower gpu clocks. and about 10% more frames fps
There's a bit of a difference, but I don't know about 15-20%. Cetainly in some tasks, but not all. Some apps probably will see very little difference, some will see more. For reference, I can clock my e4300 and e2160 (2MB vs 1MB) to 3.2GHz and can't notice any difference between the two unless I am benchmarking, and even then the difference is negligable. But, the e8400 also has a lot more than 2MB L2. I won't be going e8400 as my motherboard only does 400 FSB, so 3.6GHz (400x9) would be around my max with it, where an e8600 will get to 4.0GHz (400x10).
400 max could be due to the chips. i really doubt a 780i is going to max out at 400fsb.
1 - 9 of 9 Posts
