E2220 @ 400fsb
584 Views 11 Replies 7 Participants Last post by  SickStew
Hi OCN
I've oc'ed and tested my E2220 with 400FSB x 8 1.39v it's linpack stable
What should i increase now
Mobo = EP45-UD3P
Thanks OCN
1 - 12 of 12 Posts
nice
go for a higher multi now ... see if you can get 3.4-3.6 maybe
Even some more voltage and fsb wouldnt hurt im sure! Go for 4ghz! lol! I managed to get 3.33ghz out of my E2140.
why did you drop the multiplier?
up the multiplier.
4GIG out of a E2220 on AF7Pro
I was going to increase FSB to 500 x 7 3.5GHz
up the multiplier.
To find maximum FSB for my chip
I doubt it will pull 400x9, but I would say that is a good goal. I am just impressed you got 1600mhz bus out of that allendale!!!
May start to increase the multi. As fsb increases, more pressures on ram/nb.
I'm going for 4GHz test run once L4D is installed
What setting should I go with
400x10
333x12
500x8
what voltage as well
3.6GHz achieved @1.42v in BIOS
Should i Lin pack test it
I've got another 0.8v to play with (maximum voltage is 1.5v)
see front page
1 - 12 of 12 Posts
