You're right in worrying: this is very hot. I have two questions, and both are quite different from one another: have you checked to make sure that the CPU cooler is "seated" properly? It should be tightened down very, very securely. It's also very common to install a CPU cooler, and then a minute later take off, then check the thermal paste application, fix it if necessary, and then re-install the CPU cooler. That's basically known as "reseating" it. I did that 3 times when I installed my Tuniq Tower. I wanted to be absolutely sure it was installed perfectly because I had people tell me the importance of doing so, and what may happen if I didn't do it.
Also, are you using the latest BIOS? I know of another person who wasn't using the latest BIOS, and his temperature readings were very inaccurate and it looked like his CPU was overheating just the same as yours does. So, take a look into that if you can. Or, I can do it for you too.
Finally, if you'd like to have your system in your signature just like the rest of us, then do this:
- Click on "User CP" on the black bar at the top (alternatively, click on "Quick Links" over to the left, and then choose "User Control Panel", which is on the 3rd black bar down from the top of this little menu)
- Once you're there, then click on "Edit System" which is located on the left.
- If you have additional systems to add, then click on "Add System".
- To save it, press Enter in any field (or click Save Changes at the bottom). It won't display a confirmation page, but rather, you'll just see it scroll back to the top in the blink of an eye. When it does that, then you know it's saved.
