Theses chips are known for having fsb walls @ 300 and above
but what kind of voltage have you tried ?
mine would only run up to like 320.
Originally Posted by kylzer ![]() Theses chips are known for having fsb walls @ 300 and above but what kind of voltage have you tried ? mine would only run up to like 320. |
Originally Posted by Voltage_Drop ![]() What did you set to 3.8V, the MCH Core? Also check the specs on your RAM to make sure 2.5V isnt a little to aggressive. |
