E5200 - Overclocking Thread
490296 4652
So as the title says this is the E5x00 (former E5200) Overclocking Thread. For posting your overclocking results with links etc.
Reviews: (open to suggestions)
http://www.xbitlabs.com/articles/cpu...pdc-e5200.html
http://ixbtlabs.com/articles3/cpu/in...-e5200-p1.html
CPU-Z Verified (a screenshot is enough) - Highest Overclocks on E5200: (they are mostly suicides)
1. Nikos747 - 4.825Ghz - GIGABYTE EP43-DS3L
2. montpellier - 4.797Ghz - DFI LP DK P45-T2RS PLUS - link
3. ira-k - 4.734Ghz - DFI LP DK P45-T2RS PLUS - link
4. kaszachris - 4.55 Ghz - Foxconn P35A01 - link
5. quaaark - 4.537Ghz - Gigabyte EP45-DS3L - link
6. brandon1186 - 4.514Ghz - ASUS P5QL - link
7. Douflou - 4.504Ghz - ABit IP35P - link
8. Andrei80 - 4.5Ghz - Gigabyte - P35-DS3R - link
9. Glussier - 4.5 Ghz - ASUS P5QL - link
10. madmike0408 - 4.5Ghz - Gigabyte GA-EP45T-DS3R
spakker - 4.475Ghz - Abit IP35 Pro - link
FragZero - 4.469Ghz - ASUS P5K-E - link
celebro - 4.4Ghz - Abit IP-35E
Miloshs - 4.337 Ghz - ASUS P5Q-E - link
Lionmaster - 4.3Ghz - Gigabyte EP45T-UD3P - link%3Cbr%20/%3Einfiniteengine%20-%204.3Ghz%20-%20EVGA%20730i%20-%20link
Djhunt - 4.287GHz Gigabyte EP35-DS4 - link
PERSPOLIS - 4.275Ghz - ASUS P5QL PRO
jspeedracer - 4.261Ghz - 13.899s - MSI P43 Neo3F -link
Lionmaster - 4.26Ghz - Gigabyte EP45T-UD3P - link
3volvedcombat - 4.25Ghz - Gigabyte EP45 UD3P - link%3Cbr%20/%3EZamoldac%20-%204.22Ghz%20Gigabyte%20P31-DS3L%20-1.536V%3Cbr%20/%3EJspeedracer%20-%204.213GHz%20-%20MSI%20P43%20NEO%20-%20link
Overclockerfx 4.208Ghz - ASUS P5KC - 1.52V - link
Grandlo - 4.204Ghz - DFI LP DK P35 - link
aiboforcen - 4.2Ghz - ASUS P5QL-E - link
Ranked 4.2Ghz - Gigabyte P35-DS3 -1.508V
Cuida - 4.165Ghz - MSI P43 Neo-F - link
spakkker - 4.137Ghz - Abit IP35-E link
bucd - 4.105Ghz - DFI LP LT X48 - link
mega_option101 - 4.05 Ghz - Gigabyte EP35-DS3L - 1.472V link
auditor - 4.027Ghz - 3HRs+ ORTHOS SMALL FFT - DFI Lanparty DK P45-T2RS Plus - link
Shadowrunner340 - 4.025Ghz - ASUS P5Q PRO - link
Nutric - 4.012 Ghz - Gigabyte EP35-DS4 - 1.44V
Jihe - 4.012Ghz - Abit IP35-E
Lolcano - 4.002Ghz - MSI MS-7519 - link
Overclockerfx - 4.0Ghz - ASUS P5N-E SLI - VCore 1.468V link
Pr0Chris -4.0Ghz - ASUS Rampage Formula - link
hout17- 4.0Ghz - Gigabyte P35-DS3L
SickBoy - 4.0Ghz - Gigabyte EP45-DS3L
Dangzing - 4.0Ghz - Gigabyte G33M-S2L
^Son_Gokou08 - 4.0Ghz - Abit IP35P - link
{core2duo}werd - 4.0Ghz - 1.424V -
Jolting - 4.0Ghz - ASUS P5Q-Pro - link
wes45013 - 4.0Ghz - Gigabyte EP45-UD3LR
kylzer - 3.996Ghz - ASUS P5QSE - link
Mccaula718- 3.913Ghz - Gigabyte G31M-ES2L - link
3Dreamers - 3.9Ghz - ASUS P5QL-E
PizzaMan - 3.906Ghz - EVGA 780i - link
S2KPhile - 3.864Ghz - Gigabyte EP45-DS3L
W4LNUT5 - 3.829Ghz - Gigabyte EP35-DS3L
azlvda - 3.829 Ghz - Gigabyte EP45-UD3R - link
jnd426 - 3.829Ghz - Gigabyte GA-G31M-ES2L
spawney - 3.817Ghz - ASRock P43DE - link
MICRON - 3.81GHz - GA-EP45-DS3L
Voyager - 3.8Ghz - 1.344V - 2hrs OCCT
lolhax 3.8Ghz - 1.328V - GA-G31M-ES2L - 3Hrs+ Small FFT's ORTHOS - link
jnd426 - 3.8Ghz - GIGABYTE GA-G31M-ES2L - link
mz-N10 - 3.79Ghz - ASUS P5E Deluxe link
Retoric - 3.784 Ghz - 2 Hour OCCT - Gigabyte X38T-DQ6
wolfy87 - 3.78GHz - ASUS P5E3 Deluxe - 1.424V
Brain_Stew - 3.779 Ghz - Gigabyte P35-DS3L - 1.3V load
Vladee - 3.753Ghz - 1.32V
MICRON455 - 3.75Ghz - GA-EP45-DS3L
Crushedlizard - 3.75Ghz - ASUS P5QL-E - link
Unknownm - 3.749Ghz - 14.602s - P5B Deluxe - link
oblivion592 - 3.749Ghz - ASUS P5K SE - link
Hondacity - 3.746Ghz - Biostar I45
durch - 3.707Ghz - Gigabyte EP45 UD3R link
Ranked - 3.7 Ghz Stable 8Hrs ORTHOS - Gigabyte P35-DS3L - 1.4V BIOS, 1.36V Idle
zoieta - 3.7Ghz - ASUS P5N-E SLI - link
Pepsilove - 3.69Ghz - DFI JR-P45 T2RS
xEVHx - 3.68Ghz - Gigabyte EP31-DS3L - 1.328V - link
azlvda - 3.663Ghz
spar - 3.622Ghz - ASUS P5Q
Stepsascend - 3.601Ghz - ASRocK P43TWINS1600 - link
3Dreamer - 3.6Ghz - 10 Loops IBT - ASUS P5QL-E - 1.272V
Lionmaster - 3.6Ghz - MSI MS-7518 - link
eminded1 - 3.6Ghz - P5N-E SLI
metal_gunjee - 3.6Ghz - ASUS P5N-D
CoY - 3.559Ghz - ASUS P5Q Deluxe - link
ColdDeckEd - 3.55Ghz 24/7 - ASRock P43Twins - VCore 1.37V link
kleptodathief - 3.520 Ghz - ASUS P5Q-PRO - 1.38125v BIOS
Kinglaiho - 3.51Ghz - Gigabyte EP31-DS3L - link
The_Rooster - 3.504GHz - Gigabyte EP45-UD3P - link
BlankThis - 3.499Ghz - ASUS P5Q-E
Haste - 3.4Ghz - Gigabyte GA-E7AUM-DS2H - link
Devilywan88 - 3.4Ghz - Gigabyte EP45-UD3P
Damen57 - 3.394Ghz - JW IP35-PRO link
blooder11181 - 3.381Ghz - ASUS P5QL-SE - link
maxextz - 3.339Ghz - 1.2V - ASUS P5Q-E
bk7794 - 3.325Ghz - Gigabyte EP45-UD3R - link
AmgMake - 3.324Ghz - P5Q-PRO - link
Mason - 3.325Ghz - EP43-DS3L - link
Shunsuke_01 - 3.302Ghz - MSI MS-7519 - link
ericeod - 3.3Ghz - Shuttle Inc FP35 link
Blaze_125 - 3.25Ghz Stock Fan - Gigabyte EP45-DS3L
lionmaster - 3.25Ghz - MS-7518 - 6hrs+ Blend ORTHOS - link
Mariusmsj - 3.0Ghz - Gigabyte G31M
Quantum Reality- 3.0Ghz - ASUS P5Q-Pro - link
squall325 - 3.0 Ghz - GA-G31M-S2L
kirayamato26 - 3.0Ghz - Gigabyte EP45-UD3L
skatingrocker17 - 3.0Ghz
Post your links and ill put you up here
Highest Stable Overclocks:
Overclocks will be considered stable under one of the following conditions: (You need a screenshot to be eligible)
1. 2 Hrs OCCT
2. 3+Hrs ORTHOS Small FFT's (one loop) or 6+Hrs ORTHOS Blend (one loop)
3. Same rules apply to prime95 as to ORTHOS.
montpellier - 4.4Ghz - 2Hrs OCCT - 1.344V - link
Glussier - 4.012Ghz - 2Hrs OCCT Stable - ASUS P5QL - 1.384V - link
quaaark -4.0 Ghz - 2hrs OCCT Stable - Gigabyte EP45-DS3L - link
^Son_Gokou08 - 4.0Ghz - 2hrs OCCT Stable - Abit IP35P - link
Zamoldac - 4.0Ghz - 1.424V - 2HRs OCCT - GA-P35C-DS3R
infiniteengine - 4.0Ghz - 3Hrs+ Small FFT's ORTHOS - EVGA 730i - link
wes45013 - 3.99Ghz - 3HRs+ ORTHOS Small FFT's - Gigabyte ES2L
nikos747 - 1.2V - 3.9Ghz - 2HRs+ OCCT - GIGABYTE EP31-ES3G
Devilywan88 - 1.2V - 3.9Ghz - 5 Loops IBT - Gigabyte EP45-UD3P - link
3Dreamers - 3.9Ghz - 3Hrs+ Prime95 SMALL FFT's - ASUS P5QL-E
S2KPhile - 3.864Ghz - Gigabyte EP45-DS3L - 3Hrs ORHTOS Small FFT
Grandlo - 3.833Ghz - DFI LP DK P35 - IBT - link
W4LNUT5 - 3.829Ghz - 5 Loops of IBT - Gigabyte EP35-DS3L
azlvda - 3.829 Ghz - 2Hrs+ OCCT - Gigabyte EP45-UD3R - link
spakker - 3.825Ghz - 3 Hrs+ Small FFT's - Abit IP35 Pro
spawney - 3.817Ghz - 2Hrs OCCT Stable - ASRock P43DE - link
Pizzaman - 3.813GHz Stable 2Hrs OCCT - EVGA 780i link
miloshs - 3.81Ghz - 5 runs of IBT - Asus P5Q-E
FragZero - 3.8Ghz -ASUS P5K-E - 6Hrs+ (31Hrs) Prime95 -link
kaszachris - 3.752Ghz - 3Hrs Small FFT's ORTHOS - 1.385V - Foxconn P35A01
Lionmaster - 3.75Ghz - MSI MS-7518 - 8Hrs SMALL FFT's ORTHOS - link
xEVHx - 3.68Ghz - Gigabyte EP31-DS3L - 1.328V - 6hrs+ Orhtos - link
azlvda - 3.663Ghz - 2Hrs OCCT Stable
Overclockerfx - 3.66 Ghz 3 ½ Hours Small FFT (one loop) - 1.344V - P5KC - VDroop mod
iStrive - 3.65Ghz - Gigabyte EP45-UD3P - link
Brain_stew - 3.622 Ghz - 2+ Hours of OCCT - 1.3V(load) - Gigabyte-P35-DS3L
PERSPOLIS - 3.6Ghz - 1.264V - ASUS P5QL PRO - 2hrs OCCT
nutric - 3.6Ghz - Gigabyte EP35-DS4 - 3Hrs Prime95 Small FFT's - link
metal_gunjee - 3.6Ghz - 3Hrs+ ORTHOS Small FFT's - ASUS P5N-D
spakker - 3.562Ghz - 2HRs OCCT - Abit IP35-E
CoY - 3.52Ghz - 6hrs+ ORTHOS Blend - ASUS P5Q Deluxe - link
The_Rooster - 3.504GHz - 3Hrs+ ORTHOS Small FFT's - Gigabyte EP45-UD3P - link
spar - 3.504Ghz - Asus P5Q - 6Hrs+ Prime95 Blend
Devilywan88 - Stable 3Hrs+ Prime95 Small FFT's - 3.4Ghz - Gigabyte EP45-UD3P
ericeod - 3.3Ghz - Shuttle Inc FP35 - 6HRs+ ORTHOS Blend - link
squall325 - 3.0 Ghz - 6hrs+ Prime95 - GA-G31M-S2L
bk7794 - 3.0Ghz - 6Hrs+ ORTHOS - Gigabyte EP45-UD3R
kirayamato26 - 3.0Ghz - 2Hrs+ OCCT - Gigabyte EP45-UD3L
Superpi 1M E5200 Ranking:
Nikos747 - 11.344s - 4.825Ghz - GIGABYTE EP43-DS3L
spakker - 12.421s - 4.475Ghz - Abit IP35 Pro
Glussier - 12.765s - 4.46Ghz - ASUS P5QL
brandon1186 - 12.822s - 4.35Ghz - ASUS P5QL
Ranked - 12.922s - 4.2Ghz - Gigabyte P35-DS3
spakkker - 13.140s - 4.137Ghz - Abit IP35-E
Miloshs - 13.172s - 4.337 Ghz - ASUS P5Q-E
spakker - 13.282s - 4.112Ghz - Abit IP35-E
Zamoldac - 13.304s - 4.22Ghz - Gigabyte P31-DS3L
Jspeedracer - 13.454s - 4.2Ghz - Gigabyte G31M-S2L
Douflou - 13.516s - 4.305Ghz - ABit IP35P
Overclockerfx - 13.546s - 4.196Ghz - ASUS P5KC
wes45013 - 13.760s - 3.99Ghz - Gigabyte ES2L
celebro - 4.4Ghz - 13.764s - Abit IP-35E
Nutric - 13.969s - 4.012Ghz - Gigabyte EP35-DS4
3Dreamers - 14.078s - 3.899Ghz - ASUS P5QL-E
Jspeedracer - 4.213GHz - 14.196s - MSI P43 NEO
Pizzaman - 14.250s - 3.827Ghz - EVGA 780i
W4LNUT5 - 14.310s - 3.996Ghz - Gigabyte EP45-UD3L
W4LNUT5 - 14.524s - 3.995Ghz - Gigabyte EP35-DS3L
Devilywan88 - 14.528s - 3.9Ghz - Gigabyte EP45-UD3P
wes45013 - 14.750s - 3.91Ghz - Gigabyte ES2L
jnd426 - 15s - 3.8Ghz - GIGABYTE GA-G31M-ES2L
spawney - 3.817Ghz - 15.177s- ASRock P43DE
azlvda - 3.663Ghz - 15.070s
spar - 15.615s - 3.504Ghz - Asus P5Q
BlankTHis - 16.023s - 3.499Ghz - ASUS P5Q-E
Super Pi 32M E5200 Ranking
Nikos747 - 11m 12.656s - 4.75Ghz - GIGABYTE EP43-DS3L
brandon1186 - 12m 15.468s - 4.25Ghz
W4LNUT5 - 3.996Ghz - 13m 13.378s - Gigabyte EP45-UD3L
E5300:
idleivey - 3.5Ghz - 3hRs+ Small FFTS - Gigabyte EP45-UD3P
ADD THIS TO YOUR SIG IF YOU LIKE THIS THREAD:
E5x00 - Overclocking Thread
[CODE]
[url="http://www.overclock.net/intel-cpus/390358-e5x00-overclocking-thread.html"]:clock: [B]E5x00 - Overclocking Thread[/B] :clock:[/url]
[/CODE]
Smaller:
[CODE]
[/CODE]
Should the thread name be changed to E5x00 Overclocking Thread
  • Yes, Change it to E5x00 Overclocking thread
    Votes: 39 58.2%
  • No, Lets keep it how it is
    Votes: 28 41.8%
1 - 20 of 4653 Posts
Hmmm...I'm going to keep an eye on this thread.
Has anyone pushed this to/beyond 350Mhz FSB? Apparently they top out at 320/330Mhz.
I want to know if that's true or not.
I got it to post at 350, but it wasn't stable(only 1.33V though). I was running 340x10 a few days ago, but I cleared the CMOS and it shifted the fsb hole. No complaints though because now I can run 280FSB.
I'm running 280x12.5 for 3.5GHz at 1.362V and it seems stable. It idles at 1.39V for some reason though, but I'm not too concerned because I'm pretty sure these cpus can take a bit higher vcore due to less cache.
overclockerfx, have you had any trouble with the 1201 BIOS? Whenever I try to push it past 3.7GHz it locks up and I have to clear the CMOS in order to OC again.
338x10.5 at 1.37vcore (1.34 after vdroop) and high setting (I can't find the exact number) for NB voltage, which puts me at 3.55 for 24/7 use.
http://valid.x86-secret.com/show_oc.php?id=426874
http://i230.photobucket.com/albums/e...3h20-VCore.png
Highest stable fsb I've gotten at is 340x10.5 at 1.38. Was not able to boot into windows at 4 using a 1.39 volts, didn't want to push anymore until my new tru90 comes in.
Recently taped up the fins hs, added extra tim to the heat pipes, and lapped my cpu and have gotten a 3 degree drop in highest load temp so far. However, my temps are still somewhat high in my eyes, distance to tjmax is 55 idle, and 32-30 under orthos and occt. I'm guessing its just the crappy masscool i'm rocking though, so I ordered a tr ultima90, should get it by monday.
Discussion Starter · #12 ·
Ok nice to see some people with some good oc's going... I thought i would post my results here too since i did hit 3.9Ghz
; Just for those who are intrested on how this fairs on a p5n-e sli... I hit 3.7Ghz on 12.x multi but it wasn't anything close to stable even at 1.368V so; no chances of going further...
I was caught in the 650i's fsb hole and i could not go no further with the 12.5x multi. So i changed my multi to 11x350mhz and changed the fsb (quad-pumped) to 1400 and guess what... it booted no problemo... i was also able to quickly hit 3.9Ghz with the multi at 11x355mhz (yea thats 355mhz fsb) and fsb at 1420mhz Vcore at 1.425V and i was able to run some benches even though it was quite unstable:
CPU-Z valid:
http://valid.x86-secret.com/show_oc.php?id=424974
Super Pi 1M:
http://img509.imageshack.us/img509/5853/super39th5.png
Im quite happy with that
I might be able to hit 4.0ghz on a 11.5X multi since i think my board has another fsb hole after 1450mhz... but im sure ill need quite some volts to do that...
Note: im running 24/7 on 12.5x multi now with 3.5ghz at 1.356V completly stable... since for some reason the board has some trouble maintaining the lower multis after reboots...
Same here, I'm running 1.362V though. I haven't tested 1.356.
Although for some reason when I power off the system it won't post, so I CPR it, get into the bios and just save and quit and it posts again.
And how's your NB? I had to put an 80mm fan blowing on it in order to keep it from burning my finger when I touch it.
Discussion Starter · #17 ·
I know i have exactly the same problem so thats why im using the 12.5x multi for 24/7 since i cant reach very high speeds due to the fsb hole at ~1150mhz-1250mhz~ on this board and it wont post after a shutdown if i have my multi set to 11x or something...
My NB volts are at 1.56V... Its hot as hell but im sure it can take it quite well... since i think the NB is either 92nm or is it .13 microns... I think its in the 80C range i have thought of extra cooling but havent got around to it yet but it seems to be fairing fine so far...
I'm running mine at 1.56V too, and a simple 80mm fan does wonders for the NB. It should be fine running that hot, but if I can avoid it easily I will.
