1 - 13 of 13 Posts
Anybody using the E6300 with the Gigabyte DS4??<br />
<br />
i'm having some problems with temps and would like to find out if its due to this combination.<br />
<br />
Thx
What kind of temp problems are you having? Make sure that the HSF is tightened down enough.
<tr>
<div>
Originally Posted by <strong>tUDJ</strong>
</div>
<div style="font-style:italic">Anybody using the E6300 with the Gigabyte DS4??<br />
<br />
<br />
Thx</div>
</td>
</tr>
</table>
</div>hey can you link me to newegg with your ds4?
Discussion Starter #4
Stock heatsink + fan = 56C idle - 65C load<br />
<br />
Zalman = 47C idle - 57C load<br />
<br />
these are far too high considering i have no OC and intel say max temp is 61.5C<br />
<br />
<tr>
<div>
Originally Posted by <strong>splat00n</strong>
</div>
<div style="font-style:italic">hey can you link me to newegg with your ds4?</div>
</td>
</tr>
</table>
</div>what do you mean?
<tr>
<div>
</div>
<div style="font-style:italic">Stock heatsink + fan = 56C idle - 65C load<br />
<br />
<br />
<br />
<br />
<br />
what do you mean?</div>
</td>
</tr>
</table>
</div>where did you buy it.
Discussion Starter #6
<a href="http://www.scan.co.uk" target="_blank">www.scan.co.uk</a>
Are you using Intel's Temp Analysis Tool, or are you reading the temps from Speedfan or some proprietary thing?
Hmm, I don't see why your temps would be affected by your mobo... so I agree with bdattilo, check that your thermal paste and heatsink are properly fitted.
Make sure you double check your vCore in the BIOS. Something may be amiss there.
Discussion Starter #10
this is using TAT<br />
<br />
heatsink fan thermal paste Vcore all checked and fine
Use TAT or core temp program, the conroe runs a lot hotter than any of the other cpu's, mine loads at 58c. it has been up in the 60's. there thermal limits are rated in the 80's.
Discussion Starter #12
your wrong about the 80's<br />
<br />
<tr>
<div>
Originally Posted by <strong>Email in responce to my problem from Intel</strong>
</div>
<div style="font-style:italic">The maximum operating temperature of the Intel(R) Core(TM) 2 Duo processor E6300 is 61.4 degrees Celsius</div>
</td>
</tr>
</table>
</div>
<tr>
<div>
</div>
<div style="font-style:italic">your wrong about the 80's</div>
</td>
</tr>
</table>
</div>No I think he's right. This is using Intel's TAT which measures the cpu differently than say speedfan.
1 - 13 of 13 Posts
