1 - 15 of 15 Posts
cosidering building a C2D rig for friend...no really familiar with the mobo's on the Intel side...which mobo would be good for the E6300 (preferably Asus brand)<br />
Thanks
was thinking of the Asus P5B (non-deluxe)...but whats the performance differance between the two? P5B vs P5B deluxe?
Not a huge difference in performance, just the Deluxe is better built (lasts longer) and is a better OC'er and has more features/ports, but not a lot more.
I got a Gigabyte DS4 based on recommendations on this forum and I'm very happy with it.<br />
<br />
Ive got my 6300 at a nice stable 3.1Ghz with only 667Mhz Ram and with the minimal of OCing knowledge.<br />
<br />
The DS4 has heatsinks, a sexy looking heatpipe running the length of the board, RAID support, OC's well and for (seemingly pointless) bragging rights has solid state capacitors.<br />
<br />
So gets a big <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> from me
I don't think the DS4 is available here in North America nor it will ever but......<br />
<br />
If you're going for the long run, the P5B Deluxe is the very best but the 2nd recommendation will be the GIGABYTE DS3 with a P965 chipset. I'm sure ABIT is good but not as good as those two. The P5B (vanilla) is not as good as the DS3 IMO.
DON'T GET THE P5B VANILLA!<br><br>
The max Vdimm is 2.1V and with an E6300, you need a lot of ram voltage.<br><br>
Get the P5B Vanilla if you plan to do some hardware mods.
Discussion Starter #9
so... Asus P5B Deluxe mobo it is (im a big fan of Asus)<br />
<br />
btw...dont really want to waste much time OC-ing (cause he wants the comp ASAP Xp) so what are some good settings for a around 3.0ghz OC?<br />
<br />
thanks a lot!
I managed to get 2.8 on stock voltage by only raising the FSB.<br />
So if you want a quick OC just do:<br />
<br />
FSB = 400<br />
Memory multiplier = 2.0<br />
<br />
And turn off all the fancy/smart mobo features bar any thermal monitoring<br />
<br />
<br />
I got a stable 3.1 from the E6300 with:<br />
<br />
1.34 Vcore<br />
+0.300 memory voltage<br />
+0.1 MCH<br />
+0.1 FSB voltage
<tr>
<div>
Originally Posted by <strong>TimBitz</strong>
</div>
<div style="font-style:italic">so what are some good settings for a around 3.0ghz OC?</div>
</td>
</tr>
</table>
</div>This here is what I use 24/7: <br />
<br />
<div align="center"><a href="http://s13.photobucket.com/albums/a291/Coppi/001.jpg" target="_blank"><img src="http://s13.photobucket.com/albums/a291/Coppi/th_001.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a>___<a href="http://s13.photobucket.com/albums/a291/Coppi/002.jpg" target="_blank"><img src="http://s13.photobucket.com/albums/a291/Coppi/th_002.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a>___<a href="http://s13.photobucket.com/albums/a291/Coppi/003.jpg" target="_blank"><img src="http://s13.photobucket.com/albums/a291/Coppi/th_003.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a></div><br />
Although I've change the frequency from 333 to 334 so that way I don't see 2,999.99mhz in CPU-Z. Now I see 3,003mhz. <br />
<br />
I also change the Vdimm from 2.25 to 2.30v but I'm using a 2:3 ratio, but a 4:5 will be just fine.
Discussion Starter #15
thanks Nasgul...ill try both settings once parts get in...<br />
Thank you guys so much
1 - 15 of 15 Posts
