So I recently managed to get my E6400 orthos stable at 3.5ghz with a bios-set VCORE of 1.41v's. A pretty good temp/clock/Vcore compromise if you ask me. The actual volts, as reported by CPUz are something like 1.36v's or so ...
Anyway ... earlier today, since I was leaving the house with a fairly critical system backup in process and since I didn't want to take the chance of things crapping out in the middle of it ... I used Clockgen to downgrade my overclock to stock settings ... BUT with the same volts ...
After work, when I got home, I checked my temp logs and what I found was that the temps were about the same ...
Is that wierd or what?
3.5ghz w/ 1.41v's = 37C idle temp
2.13ghz w/ 1.41v's = 36C idle temp
So, does VCORE *really* affect temps that much?
I thought my temps would be *drastically* lower once I Clockgen'd down to stock speeds ...
