1 - 5 of 5 Posts
the cpu cooler is Freezer 7 pro, no extra cooling for the mobo.<br />
case: antec P180.<br />
<br />
the RAM is: 2GB Cellshock (2X1024) DDR II - PC6400 4-4-4-12 800MHz<br />
<br />
any recommended settings?<br />
could I reach 400+ FSB?<br />
<br />
(I haven't ordered the system yet so I can add/change my selections)<br />
<br />
thanks!
You should be able to hit 400mhz FSB easily. I don't know too much about the ram, but if it doesn't like overclocking you can just put it on a divider then you should be fine.
Discussion Starter #4
great, so the mobo is not going to melt...<br />
<br />
I had some thoughts on getting a 6300 + S3 instead and saving 100$ but I think I'll stick with this config.<br />
<br />
thanks!
Yup, the DS series are great boards. Not so sure about the 4's overclocking potential but I know the 3 can hit 500FSB.
1 - 5 of 5 Posts
