I'm currently running at 2.85GHz with vcore at 1.250 in bios (1.216 after vdroop). Idles in the 30'sC. Normal surfing etc in the high 30's. Light gaming in the 40's. If I run Ortho and monitor with TAT the temperature stabilizes aroung 54-58C after about 10-15 minutes. However, ASUS Probe and MBM5 show CPU temperature 5C HIGHER (63C) and the MB temp is around 39C.
Should there be that much difference between the CPU temp and the core temps?
Should I stay with my current settings (seems kind of a sweet spot) or do I have enough leeway to up it?
BTW it's a week 29B. P5B deluxe, Scythe Ninja.
thanx,
John
thanx,
John
