When I look at it on RealTemp or Coretemp , the minimum it shows is 38c on both cores. It won't "show" any lower , for a little bit I thought it was messed up and stuck but all of a sudden I seen it move on one of the cores to 39c , 40c etc. Then it dropped back to 38c.
I am used to watching my core temps on my i7 920 but this one acts different , cores not jumping around like normal , just sits at 38c and doesnt move unless its stressed. This makes me think somethings wrong with the thermal whatever it has in it not showing it going lower. With it not moving much I think it is actually idling lower than 38c which is great but I just wish it would show up
This is a new cpu I just installed last night so all the temps are new to me.
Using a Asus P5N-E SLI motherboard.
Also does these temps sound right for it stressed on Intelburntest? On maximum 100% loaded , highest it recorded on RealTemp was 46c on both cores but it looked to be more in the lower 40c's for the duration of the test.
This was at stock clocking , Noctua NT-H1 paste / Arctic Freezer 7 Pro.
