1 - 10 of 10 Posts
I'm trying to oc my e6600/P5B Dlx rig to 333fsb. All is fine at 300 and 320, but when I go up to 333 I start getting rounding errors when running Prime95 LARGE FFT test. The SMALL FFT test runs fine for hours with no errors.<br><br>
Here are my settings...<br><br>
FSB = 333<br>
DRAM = 666<br>
PCI = Locked @ 33.3<br>
PCIE = Locked @ 100<br>
Spectrum Spread = DISABLED<br>
CPU Core V = Tried between 1.3 and 1.35<br>
DRAM Timing = 5-5-5-15<br>
Static Read Control = Tried both AUTO and DISABLED<br><br>
Am I correct in assuming that since only the Large FFT test fails my issue probably lies with memory? My ram is Corsair Twin2X DDR 800 5-5-5 (2gb, 1gbx2) I've noticed that other here have been using SPECTRUM SPREAD set to AUTO. Should i try that?<br><br>
Also, what about increasing the voltage to my VCore? I've only gone as high as 1.35 since my cpu tends to run a little hotter than the average 6600.<br><br>
Thanks
<tr>
<div>
Originally Posted by <strong>spiderhole</strong>
</div>
<div style="font-style:italic">I'm trying to oc my e6600/P5B Dlx rig to 333fsb. All is fine at 300 and 320, but when I go up to 333 I start getting rounding errors when running Prime95 LARGE FFT test. The SMALL FFT test runs fine for hours with no errors. <br />
<br />
Here are my settings...<br />
<br />
FSB = 333<br />
DRAM = 666<br />
PCI = Locked @ 33.3<br />
PCIE = Locked @ 100<br />
Spectrum Spread = DISABLED<br />
CPU Core V = Tried between 1.3 and 1.35<br />
DRAM Timing = 5-5-5-15<br />
Static Read Control = Tried both AUTO and DISABLED<br />
<br />
Am I correct in assuming that since only the Large FFT test fails my issue probably lies with memory? My ram is Corsair Twin2X DDR 800 5-5-5 (2gb, 1gbx2) I've noticed that other here have been using SPECTRUM SPREAD set to AUTO. Should i try that?<br />
<br />
Also, what about increasing the voltage to my VCore? I've only gone as high as 1.35 since my cpu tends to run a little hotter than the average 6600.<br />
<br />
Thanks</div>
</td>
</tr>
</table>
</div>Have you increased the Northbridge MCH voltage any? You will need to for high fsb.
Increase northbridge MCH voltage? But how will you measure if that is stable or running too hot. Sounds risky.
The asus probe utility tells you the mb temp<br />
<br />
It's not risky, but better temps will hit better fsb typically<br />
<br />
You add voltage until it's no more benifit from it.
I see. What a safe mobo temp then? And the best Prime95 test to see if its all stable, CPU/Mobo? I use torture test.
Asus probe sets off bells and whistles if it goes over 45c
Increase the FSB termination voltage and the NB voltage up one notch and try again.
<tr>
<div>
Originally Posted by <strong>OCZedd</strong>
</div>
<div style="font-style:italic">I see. What a safe mobo temp then? And the best Prime95 test to see if its all stable, CPU/Mobo? I use torture test.</div>
</td>
</tr>
</table>
</div>lol, a pc here at school runs at 65C all day with no probs.. yes that's right, the mobo. The cpu (p4 2.8) runs even at 72-75C idle (up to 85C load <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />)<br />
That's also some ASUS board, so I'd guess it's fine..
1 - 10 of 10 Posts
