I have E6600 running at 3.4GHzon a ZALMAN 9700 HSF running around 38C idle, 56C under CPU torture by Orthos. Core #0 is 31C and Core #1 is 30C on idle.
Ram is running at 1058MHz at 5-5-5-15 2T timings and CPU is at 1512MHz FSB. Questions:
1) Can this CPU with these setting run faster? Even if it can handle more juice would it be recommmended given the fact that the CPU's life would be shorthened as much as it gets overclokced?
2) Do these temperatures sound ok?
Thank you all for the inputs. Greatly appreciated.
