1 - 7 of 7 Posts
hi every body thanks for nice forum<br>
i overclocked my new cpu and i don t know how i can do it better<br>
ram timing is on auto i don t know which timing is good<br>
thanks<br><a href="http://valid.x86-secret.com/show_oc.php?id=135361" target="_blank">http://valid.x86-secret.com/show_oc.php?id=135361</a>
Your RAM is indeed limiting your overclock right now. It's running at 534MHz, or DDR2 1068 speeds (pretty nice RAM overclock!) on a 2:3 divider.<br><br>
You should put the ram in a less aggressive divider, like 4:5 or even 1:1. To achieve this, set the RAM speed at DDR2 667 or DDR2 533 speeds. You should be able to easily run timings of 4-4-4-12
Reactions: tankguys
Generally speaking, the best ways to help your overclock are:<br><br>
1 - Run a divider on your memory, to prevent it from trying to run to 'fast'<br><br>
2 - Loosen the timings on the memory.<br><br>
3 - Try playing with the multi and the FSB. Sometimes you get better results with a higher FSB and a lower multi, sometimes the other way around.<br><br>
4 - Adjust your CPU/Memory voltages.<br><br><br>
Overclocking is almost as much of an art as a science <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"> For the best OC possible, you need to have a lot of patience, and the willingness to do a lot of tinkering. It's not as easy as pumping the FSB and calling it good.<br><br>
Also, realize that if you play with voltages, you risk destroying/damaging parts, so do so sparingly.
Discussion Starter #4
thanks dears ,really thanks <br />
<a href="http://valid.x86-secret.com/show_oc.php?id=136048" target="_blank">http://valid.x86-secret.com/show_oc.php?id=136048</a><br />
look there what you think?
That's looking pretty good!<br />
<br />
What are your temperatures at those settings ?<br />
<br />
Hey Tankguy... I like your new postbit.. vendor rep eh <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Reactions: PMD
Discussion Starter #6
cpu:32 with thermaltake bigwater 745 on full<br />
sys:41
Discussion Starter #7
Freq : 3420.03 MHz (380 * 9)<br>
RAM Freq : 380 MHz<br>
RAM Type : DDR2-SDRAM Dual Channel<br>
RAM Ratio : 1:1<br>
RAM Timings : 5-5-5-15<br><br><a href="http://valid.x86-secret.com/show_oc.php?id=136864" target="_blank">http://valid.x86-secret.com/show_oc.php?id=136864</a><br><br>
Freq : 3439.37 MHz (429.92 * 8)<br>
RAM Freq : 429.9 MHz<br>
RAM Ratio : 1:1<br>
RAM Timings : 5-6-6-16<br><a href="http://valid.x86-secret.com/show_oc.php?id=136798" target="_blank">http://valid.x86-secret.com/show_oc.php?id=136798</a><br><br>
which one is better?<br><br>
i have to oc ram with the same core speed (Freq : 3420.03 MHz (380 * 9)<br>
but this ratio : 1:1<br>
RAM Timings :4-4-4-8<br>
how i can to do please hep me<br>
thanks
1 - 7 of 7 Posts
