1 - 9 of 9 Posts
I've got my C2D E6700 & Asus P5B Deluxe @ 3400 MHz. on an Artic Freezer 7 Pro CPU fan cooler.<br />
<br />
340 X 10 = 3400 MHz.<br />
DDR2 680 MHz. Mem. Voltage @ 2.25v<br />
Vcore @ 1.45v<br />
FSB Term. Voltage @ 1.40v<br />
NB Vcore @ 1.45v<br />
<br />
Temps are @ low 40's idle, and 58-62 @ 100% load, do you think I will be safe running these temps 24-7 or should I drop back some?<img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /> <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
Bod ***s rock
i would say that those temps are ok
I would drop back some, the upper 50's and 60's are pushing it quite a bit. Nice OC though!
Discussion Starter #4
Yea, I am looking at going to water by X-mas.<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <br />
<br />
Just wondering if I will be ok until then?<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
If I rememer correctly, the temp threshold for the C2D chips are a lot lower than the prescotts, so I would try to keep it under at least 55 or ideally 50 while under load.
Discussion Starter #6
I agree, this is what I get for temps when running @ 3330 MHZ and stock voltages.<br />
Anything over 333 is when I have to start upping the voltages.
nah you can keep it at those temps until christmas easily <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I remember when......
It is odd that the TAT program is reading a LOWER temp than your Ai Suite......but that happens I guess.....Ai Suite is not always accurate.<br />
<br />
The TAT temperature is read from the core, the max temperature guidelines given by Intel is approx 60c..........an overclcoked CPU shoul dnot be run at the max temperatures.......<br />
<br />
At that voltage, Christmas is about the only guess I would give <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
I am running at 400x8-> 3.400ghz....but vcore in bios at 1.38v, in windows, 1.34. CpuZ also reg'd vcore at 1.34v. I think you could lower your a little. Have you tried to bench @ different vcore settings to see if you can find an "optimal" setting? <br />
<br />
*I have not had the need to hit 1.4v until 3.45, and that voltage was acceptable through 3.55ghz.
1 - 9 of 9 Posts
