1 - 13 of 13 Posts
I was just messing around today and was able to OC my E6700 & Asus P5B Dlx. from the stock 2666 MHz. to 3700 MHz. on air.<img src="/images/smilies/gunner2.gif" border="0" alt="" title="Gunner2" class="inlineimg" /> <br />
<br />
Settings:<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> <br />
<br />
370 X 10 = 3700 MHz.<br />
DDR2-740<br />
1:1 Divider<br />
Ram Timings, 5-5-5-12-6-35-10-10-10-10<br />
Ram Volts, 2.25<br />
Vcore, 1.528<br />
<br />
Temps: 45c & 46c Idle & 60c & 61c 100% Load with TAT.<br />
<br />
One thing that I can't understand though is the fact that I have to run my Ram Voltage at 2.25 running @ DDR2-740 Ram speeds, that isn't even the stock 800 MHz. ( Whats up with that, any ideas?)<br />
<br />
( I can't wait to get my water cooler!<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> )
nice job <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
wow NICE JOB!!! <br />
<br />
im trying to keep the temps safer than that though.. u got me beat by a long shot!!!<br />
<br />
im at a measly 3.2ghz atm <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> im so owned... LOL
Since you're on a 1:1 ratio your RAM speed is simply twice your FSB. <br />
<br />
FSB - 370<br />
RAM - 740<br />
<br />
If you lower your multiplier to 9, have your FSB set to 400, your RAM would then be at 800 while running at a still speedy 3.6 GHZ. Might be able to make the most of such a high volatage that way perhaps. May or may not work out for you.
<tr>
<div>
Originally Posted by <strong>ElMikeTheMike</strong>
</div>
<div style="font-style:italic">Since you're on a 1:1 ratio your RAM speed is simply twice your FSB. <br />
<br />
FSB - 370<br />
RAM - 740<br />
<br />
If you lower your multiplier to 9, have your FSB set to 400, your RAM would then be at 800 while running at a still speedy 3.6 GHZ. Might be able to make the most of such a high volatage that way perhaps. May or may not work out for you.</div>
</td>
</tr>
</table>
</div>Plus your temps would probably drop just under that 60C mark too.
Discussion Starter #6
Yea, I understand that but what I am saying is that the Ram shouldn't need that high of a vlotage to run under the factory speed of 800 MHz. ( right?)<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
When your system is at stock speeds have you tried adjusting just the RAM itself to 800? If so, does it require that much voltage to do run stably?
Discussion Starter #8
No it dosn't need that much to run at DDR2-800 at 2666 MHZ, but it needs 2.25 to run at DDR2-740 at 3700 MHz.
my ram is runing at 2.25vdimm atm and at speeds of 1067 and 5-5-5-10 timings! so considering my ram is suppose to run at 2.2 stock.. ur vdimm should be fine <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>hogans</strong>
</div>
<div style="font-style:italic">I was just messing around today and was able to OC my E6700 & Asus P5B Dlx. from the stock 2666 MHz. to 3700 MHz. on air.<img src="/images/smilies/gunner2.gif" border="0" alt="" title="Gunner2" class="inlineimg" /> <br />
<br />
<br />
DDR2-740<br />
1:1 Divider<br />
Vcore, 1.528<br />
<br />
<br />
<br />
( I can't wait to get my water cooler!<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> )</div>
</td>
</tr>
</table>
</div>yep is called vDimm droop...the P5B Deluxe voltage readings in the mobo/bios are way off of accurate. I will say this though thats a fine OC on 1.528 BIOS set vCore. Now if that actual vCore then thats pretty much par for the course.
So whats a good conroe mobo that doesnt vdroop on vDimm and vCore but is still a good overclocker and has good features but isnt expensive? <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
My Gigabyte GA-965P-DS3 didn't have much or even any vdroop for Vcore.<br />
But it did not allow me to boot my RAM at or above 2.3Vdimm (+.5V).<br />
<br />
\\/ Nah the amount of voltage I could place on the RAM was not holding my OC back.
<tr>
<div>
Originally Posted by <strong>ckp64</strong>
</div>
<div style="font-style:italic">My Gigabyte GA-965P-DS3 didn't have much or even any vdroop for Vcore.<br />
But it did not allow me to boot my RAM at or above 2.3Vdimm (+.5V).</div>
</td>
</tr>
</table>
</div>2.3V is quite high though, but if its holding you back from OCing further then damn. <img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" />
1 - 13 of 13 Posts
