e8400 E0 @ 3.6 and counting
536 13
Using Easytune i've got it to 3.6 - 1600FSB under load about 50-51c. What temp should i keep it under if i wanna keep it going further?
Reactions: h00chi3
1 - 14 of 14 Posts
Originally Posted by h00chi3 View Post
Go higher. I won't break 60°C, but that is my personal temp level... Those 8400's will go higher!!!
i'm gonna play some games with it tonight at 3.6 and see how it does, tomorrow i'll give it a go at 3.8 or so. thx for the info! i'll keep you updated.
I never disabled my speedstep, and i have quite a big OC on my E7200. Disabling it does nothing to my OC. (There's a bit of discussion in the link in my sig about the multiplier).
And yeah. 8*00's should be able to get close or over 4GHz fairly easily.
And I have this bookmarked: http://www.tomshardware.com/forum/22...perature-guide
Really helpful. So the temp limit for yours is up around 80 deg. 50 is actually cool for that series.
i see you have the same mobo as me, do you have a newly flashed bios or anything?
Originally Posted by gabe1231 View Post
also is there a way to disable the speedstep? thats what makes it automatically raise and lower the multiplier right depending on load? isn't that bad for ocing?
It is really bad for overclocking. You should definitely set it disabled -mode. I think it's the one thing what have made your E8400 unstable.
Do you have proof?
And he never said it was unstable, he was worried about the temps.
Kickin n screamin
Why are you using easy tune?
Software Ocing is no good, no matter what.
Use your BIOS, that's why it's there.
Keep it under 65 to be safe.
1 - 14 of 14 Posts
