1 - 7 of 7 Posts
already posted this once before. but now its just annoying me because i dont know what my actual temps are.
my temps are idle at
realtemp: core 1: 47 core 2: 32
core temp: core 1:52 core 2: 37
basically something is jacked up with my core 1. i have reseated my cooler 3 times. all 3 times i almost punched my cooler of how frustrated i became with the push pins.
whats wrong?!?
whats wrong?!?
Your cooling passively too...might account for higher temps. Maybe you need to lap the heatsink?
i didnt have this problem before with my e6320.
i have an exhaust fan right next to my heatsink, as well as an intake fan in the front of my pc. i dont think mid 30s are bad temps...unless the apocalypse is coming
A temp difference is normal, with any dual core chip. Mine is normally 3-5c different.
And from searching around google, this forum and other forums, apparently others with similar intel ships have also had an 8-12c difference in cores.
And I have seen no real fix for the issue anywhere.
But my take on it, as others have said, is its probably on off sensor.
have you tried running prime95 for a couple hours on stock to see what temps you get on a full load?
1 - 7 of 7 Posts
